Help! Lost my body!
I’ve lost the body text of my CMS content. Everything else is there, but the body has gone, and there’s nothing to see, edit or create.
The content is still there, as existing blog entries display correctly. I’m not sure what has happened. Any ideas?
I reported the bug last week…
Hopefully fixed soon…
If your using Claude have it examine the software
2 Bugs
Thank @MichaelDroste - at least it’s not me with my setup.
I’m not using Claude.
It will get sorted soon :slight_smile:
Great! I have the same problem and was already puzzling over what’s going on. Hopefully the fix comes soon.
@tpbradley let me know if you need the email again - sent to support@……
Best always
-Mike
Hi @RichardPhoto @MichaelDroste @gkoeder
Thanks for the reports — and thanks Mike for digging into this earlier.
It’s the same problem as the blank CMS admin login. Publish was re-minifying files that were already minified, which mangled the online-editor assets, so the body field never shows up even though the content is still there on the site. I’ve got a fix in place for the next build of Elements which should be out later today :tada:
Once you’ve got the new build, republish so the fixed assets are applied.
Cheers
@RichardPhoto @MichaelDroste @gkoeder new build is now live, give it a try and let us know how you get on!
I just installed the update and did a quick test: the content is now showing up in the editor again for me. Thank you very much for the quick help!
Thanks @dan - I have my body back! I appreciate all the hard work you and your colleagues are doing. Now I’ve adapted to Elements (from Classic). I’m really loving it.
That is awesome to hear, thank you :folded_hands:
