Help on counter Fitness Project
I am using the fitness project calculator and need to either have more than 100 as total or to put a “'s” after the hundred - which is current maximum. The “'s” would most probably be more effective as the number currently stands at 427. TIA @dan @ben
easiest thing is probably just change the max setting on the number slider property.
If you want something more polished with additional options there is now a Number Ramp component available on the store.
Hope that helps :slight_smile:
THANKS for your quick response, very basic at moment but will look at the posh one. I didnt look in properties just template. You’re a STAR!!
