Help rebuilding in Elements
The above link is to a page built in RW Classic. This is not live. It is a working rebuild.
I have 10 years to add to this. Any ideas for getting started in ELEMENTS? I do have a tailwind account if anyone has seen anything there that is close.
Thanks,
-ed-
You could start to build this out quite quickly with the built-in Templates.
Let me know if you get stuck or have questions, I can put together a quick project or do a video for you :slight_smile:
Dan,
Thanks for your response and input.
I come out of the RW Classic background using the Foundations Stacks, so I am used to thinking in those terms. Forgive me if my questions seem elementary.
While Elements feels more user friendly, I believe that I may be trying to overthink this and make it more complicated.
You say that I can do this with the built in templates. Are you referring to the ones in Elements that set in the left hand frame? I am on my iPad now and don’t have access to my laptop or desktop, so I am not sure how else to describe. While watching some of the Elements YouTube videos, I saw how you took a grid and added columns. I will see how far I can get. I also saw how to copy and past in the sidebar that shows all of the elements (is that the right term?) to create duplicate lines, etc.
I will let you know if I am having any problems. I may create a sandbox for what I have completed so far and to share.
-ed-
