Help required
I am getting and API request failed [401] when trying to login to control panel?
Daz.
Hi @DazFisher
Which control panel are you referring to?
EDIT: Did some digging around, located the error you were referring to. All fixed up, you should be able to log in now. Thanks for the heads up. :folded_hands:
