<div class=>Type whatever you like in here!</div>
@ben @dan I have an image in folder images/x.png and I wish to replace text - Type whatever you want in here above with the image. What code do I need to change the above to, to meet my goal.
TIA
You can turn it into a dropzone, that way you can add any component in between the div tags.
So from this:
To this:
<div class=>@dropzone("extraItems")</div>
You can learn more about Dropzones here: Dropzones | RapidWeaver Elements Docs
As always brilliant I was playing around with src: and was “failing” so THANKS all sorted and running brilliantly.
