Sorry, I forgot to mention it - I’m using SiteMap Plus.
I found the setting “disable” that was checked accidentally!
I will look at Integrity Plus
Thank you!
Thank you!
If you’re not using any generated pages then sitemap plus does a good job for creating a sitemap.
If you use something like armadillo, Poster, or goCMS then those posts won’t be there.
Search engines like Google will still find these pages, crawlers are called crawlers because they “chase” links. They just don’t show up on the console if they aren’t on the sitemap.
Hi Doug,
You said Integrity Plus will include external page, do you think it will include Ecwid generated pages? I’m having a hard time making a site map for Ecwid Product pages (other that manually making one). I looked at the website, but can not tell.
Natasha
Here is one I just created from your site with Integrity Pro
Hello Doug,
No, it does not include dynamic pages. I wonder if it even possible. Tried to look it up, Semrush comes up like it possibly could, but when I tried to do it, it makes a site audit (possibly by following the map that I provide), not making me one.
So it looks like the only way is to make one myself? As a txt file with just the links, and upload it as a second sitemap?
Natasha
