Hi there! I´m having a error with a form, please some help!
I’m working in this web but the contact form when you click in any it’s open a mailto: I don’t know how to take this off from the contact form. any ideas? why this is opening a mailto: new window
whttps://folik.es/Contacto-y-Formularios/
thanks!
Sounds like you are just using a simple mailto: anchor link? If so, then that will not work with a contact form.
Something like Formsnap may be a better solution :wink:
thanks, I’ll check the HTML code on this page for mailto: :slight_smile:
