dan has hidden the scrollbar on the right in one of his videos, couldn’t find in the documentation how to create it, anyone have an idea or solved the problem themselves in the settings?
it doesn’t work for me with css and js, either scrollable with bars or no scrollbars and no longer scrollable.
i am beginner level, onboard one week, patience
was the same problem I had when I started. Might be good to point out in the docs.
Thanks, oh good to know, are these settings also valid for MS Edge or other browsers? I have tried it with different ones without success. if the solution also works on Win systems, then that fits.
I generally test with safari and Edge currently
I would not worry about this. For designing its annoying. But when you have the final page it switches based on the device width. So it will show only one layout anyway.
So for me I do not really care about that for the end result. Or could you tell as a user if the switch is a 390 or 410 pixel width. In the end its a end user setting you have no control over.
thank you, yes you’re right, sometimes we want too much of a good thing ![]()
