Home page in Aspen theme italicizing words
I can create a page in Stacks using the Aspen theme and things are fine. If I do the same thing on the home page (or if i switch a correct looking page to the home page) the words look different. I have turned off all html and other formatting with no luck.
On home page
Any other page
Sounds like the text still has some formatting applied, very strange.
Could you try re-creating the page?
I recreated it 2 times before. Rebuilt it with plain text and then it looks fine. When I switch it to the home page (by deleting the current home page first) it changes.
Can you send over the file to dan@realmacsoftware.com so we can take a look?
Okay, mystery solved!
It was an incorrectly closed italic tag in the override default page title :wink:
Here’s the correct code for you:
<i>Fredericksburg</br>Ballet Centre</i>
Only a nitwit would do something like that!
Thanks for the help.
-Nitwit
Haha, we’ve all done it before, it’s an easy mistake to make!
I’m just glad we got it sorted for you :smiling_face:
