How do I change Licence number after upgrade?
@dan How do I change my licence code as I can not find anywhere to do it and when I open ELEMENTS I have old licence code. Also this will not affect my projects or work already carried out? TIA
Thanks for upgrading :smiling_face_with_three_hearts:
You can deactivate your old license in the Registration window, go to Elements > Registeration… then deactivate any machines via the drop down in the window, you should then be able to enter your new license.
Happy Weaving :saluting_face:
@dan All done! Wow blog, CMS, TWIG, e-commerce and everything else all set up! OK it’s nearly there. Keep up the brilliant work your all doing and so excited for future.
And as ALWAYS THANKS for your quick response!
