I would like my reveal of text enter from the left on desktop and enter from the right on mobile. Can this be done? I don’t see a dot to override on the direction setting.
like this, had to use hidden though
bit of a hack using hidden
Thanks @upssjw. I’ll review your file later.
I got it working. It’s a bit tricky to figure out what to hide and where to hide it. This should get easier for me once I get further along building my site in Elements.
I just created 2 one on top of each other then hid and show them at the different break points for change of direction
I too would prefer an override option for different breakpoints. @dan ?
me too, only way I could do this
The reveal animation settings can’t support different values at the different breakpoints. You’d need to hide and show different components based on the breakpoint (as @upssjw suggests), it’s a bit messy, but it works.
When I’m using the reveal component, I try to ensure the same motion works at all breakpoints.
still trying to get this to work just using Reveal
You could integrate reveal with the responsive breakpoints using gsap.matchmedia feature the same way when working within breakpoints as other features in the app if desired.
