It was easy to remove in RW Classic the “Made in RW” badge but I dont know how to do this with the “Made in Elements” badge that annoyingly keeps popping up when I go to publish. Please help
Hi, this depends on the plan you subscribed to. If you update to the PLUS subscription, you will not see this any longer.
Oh ok. Im on the base subscription, does that mean I cant get rid of it?
you cant get rid of it in the Elements badge in the BASE version. This is a feature of the PLUS version and higher.
Or the Plus version
Ah I didnt know that, thats a bit annoying but good to know thanks
Frankly, I think this is absolute crap. I pay for a product but I cannot remove your branding on my site? What madness is this? This is the slow creep of enshitification of all products. How do I go about getting a refund or must I take this up with the App Store?
No need to be rude… A friendly question can solve a lot of things here… ![]()
