I am working on a new project. I have the same pages in DE and also in EN in one project. Now I want to add alt-information to the images. The way I wanted to do this is to click on an image inside the page, then add alt text, which seems not be possible. I need to use the resources.
If I look at the resources I can add one alt-text for the image, but if the same image is used for different languages, this will not work.
Is there a way to do this without duplicating each image and have another name and resource for the second language?
If you’re using an app-only approach, you’ll probably need to maintain separate image assets within your resources. That means creating a dedicated image folder for each country and providing country-specific images and alt tags.
With ECMS, I would handle it like this:
# BANNER & IMAGE
media:
header:
960x540:
src: "/images/960x540/online-shops.webp"
title: "Online-Shop erstellen"
alt:
default: "Online-Shop erstellen"
de: "Online-Shop erstellen in Deutschland"
ch: "Online-Shop erstellen in der Schweiz"
at: "Online-Shop erstellen in Ă–sterreich"
copyright: "meinedomain.com"
type: "remote"
This way, you only need a single image resource, while the alt text can be localized dynamically based on the selected country or locale.
