Hi guys. I trying to find my way around using Elements. I want to embed an Ecwid store. I found something where I can place a html component (custom + html). Placing it there it displays a text called: “My html Element”. Any suggestion where I can easily place my code snippet from Ecwid? Thanks a lot
Found the answer myself in this video tutorial: https://www.youtube.com/watch?v=FeNoKUzd_fg
Just needed to access the inspector where I can change the html code easily :))
Ah great, glad you got it sorted! ![]()
If you ever run into anything else or want to do something more advanced with custom components, just shout. Always happy to help!
EDIT: That video is a little outdated now, there’s a step-by-step guid in the manual here ![]()
