You’d think this would be really easy. But there’s nothing in the inspector pane to set the title. The documentation at Button | RapidWeaver Elements Docs says nothing. A documentation search explains how to write some code, which is ridiculous for what should be dirt simple.
If you’re talking about the text in the button, double click on it.
Thank you. So it does turn out to be dirt simple. The documentation should have said something.
