How to style divider lines in Foundation Top Bar - need a dotted line
I need to create occasional horizontal dividers between page links in my Drop Down menus. Using Foundation’s Top Bar - easy enough to do using
, and colour adjustment is easy using the ‘accent’ setting.
However, I need to have a Dotted Line - not having any luck with my attempts at inline styling or CSS. Anyone know how to do this?
Try This:
.top-bar-section .divider{
border-top:dotted;
color:FFFFFF;
Many thanks Scott - works very well except the sizing doesn’t seem to make any difference in RW. Not critical but I’d like the dots to be smaller if possible.
Try throwing an !important after the size statement
Thanks - tried this but no luck. I’ll take a fresh look tomorrow
