Html code for tables
@dan you wont remeber but when I first came here I needed atable with some coloumns and you wrote some html code for me and I still use. But is there a way to make 1 row a different colour to signify a different event.
2026 Calender
I want to try make events different from race events?
Sure, do you have the custom component code for the table? If you can share just that table in a project I can fix it up for you (via Elements Cloud) :smiling_face:
like this?
elementsapp://downloadDocument/IG8mHBsQvsE0
just need certain rows a different colour
Looked at your site. Structure seemed similar to*Adding HTML Snippets to Elements
Just add (or your preferred color)
<tr style="background-color:pink">
tested via Safari Inspector. Screen shot below.
Brilliant…Thanks for your help Phil
