HTML Components
I am using something called jAlbum to produce image galleries. This requires an iFrame in HTML on the relevant page.
I create a custom HTML, add to my page, add the relevant code and great it works.
So I create the next page and create a new HTML custom component. Firstly I cannot rename it the so it is impossible to distinguish from the first one and secondly if i change the iFrame code in one, it changes the other as well - so I cannot have more than 1 HTML component in a site!
Is this an issue not addressed as yet or a bug?
You can change the name see below, not sure is this is what you are referring to
@dan is it possible to give @upssjw a job @realmac? He’s always helping us out and always kind!
Yes he is very helpful, and must spend hours online!
I hadn’t appreciated that renaming HTML wasn’t the same as right clicking them in the component panel.
all well now, thank you all.
two iframes on one page both on my website
