I am trying out CMS and everything works apart from images
I have copied and edited the Appleseed daily download replaced the bot images with mine and they do not get displayed yet everything else is the same. just the image is different titles all in lower case (.jpg)
I have edited a couple of the posts and they display correctly but no images. the images are under 60 kb is there a set size for these images for them to display?
Hi @graham-sm1th,
Sounds like it might be a path issue…
Can you share your project via Elements Cloud and post the link here so we can take a look for you!
Trying to but just get a spinning wheel The images are in the same images folder just with different titles
Here are some screen shots of the rendered results
As I said before all the settings are unchanged apart from the image and text
I really need to look at your project to find out what’s going on. I can’t tell by just looking at those screenshots.
Can you please share the project via Elements Cloud, details on how to do that can be found on the Elements Cloud page in the manual.
You can also send the link (or zipped project) via email to forumsupport@realmacsoftware.com
I had to re register again but here is the link
elementsapp://downloadDocument/m9NxjyHlUt95
Hi @graham-sm1th,
Your project had a while host of issues, I’ve fixed them all up and it’s now working, here’s the link to the updated project: elementsapp://downloadDocument/1rOUPopLQACd
However, there is one issue left - Author names not appearing on posts, this is actually a bug in Elements and one we’re working on fixing right now. There’s nothing you need to do in your project, just update to the latest version of Elements when it’s available later today.
Cheers!
Thank you
