Having just updated my elements to 1.6.1 my image slider has thrown a wobble. I have an image slider set to auto and it has been working great. I have 5 images which slide through one complete revolution and then stops. so I have the 5 images seen twice and then nothing. I also have another slider with 7 images, this rotates once and then stops and the right/left chevrons freeze. As this is a commercial project I will wait here for an hour before sending it to support address @dan
Ive sent project to support email just now TIA @dan
Thanks Paul, we have your project and are looking into it.
If this project is mission critical, you can downgrade to a previous version while you wait for a fix.
I tested the project file in v1.6.0 and it’s the same behavior. Didn’t test lower than v1.6.0.
I’ve found the issue and fixed it. This fix will be out in the next update of Elements. Apologies for the inconvenience!
No need for apology thanks for fixing!
