Images - custom aspect ratios at different breakpoint
Hey Team,
I was just trying to use different custom aspect ratios on different breakpoints. That does not work at all. It works when I chose tall or wide on different breakpoints, but using a custom aspect ratio (like 6/8 on mobile and 8/6 on laptop and up) does not change a thing. And yes, the little blue dot to override the mobile setting is active :wink:
Hmm, that seems to be working here…
Do you have an example project showing the issue?
Thanks for the video @dan. I wasn’t able to see the blue dot in front of the custom ratio field clearly. It’s hard to notice since it’s nearly buried under the “C” of “Custom…”. Problem solved.
Ah yes, we do need to fix that little visual glitch :thinking:
