Index.php not loading correctly
These files are not loading - see screenshot.
Restarted RW, did an “republish all files”, did a complete new upload to the server.
How can I solve this? Other subpages are loading correctly.
Thanks for any assistance.
Sequoia 15.5 | RW 9.6.2 | M1 MacBookAir
Site: https://www.familienstellen-nuernberg.de
Subpage working: Anmeldung Familienstellen Nürnberg
SOLVED - the provider Host Europe had changed the folder (migrated) serverside for the website. Found it after a long search. Site is working now again.
Hi @capetom,
Gld you got it resolved.
At the moment, only your favicon is returning a 404 - you might need to look into that.
Erwin
Thanks Erwin,
will check.
Tom
