Inspector Behavior
I have a request: The inspector should always start with everything collapsed. This way, I can see which options are available. If I open an option, it should remain open in exactly the same way when I switch to another element.
Currently, when I create a new element, all options are open. This is confusing and simply too much. Less is more.
It would be great if this could be made clearer and more organized.
Thank you.
I think you can achieve this by activating Single Group Mode, which can be activated by right-clicking on a setting group.
I agree it would be really helpful if, when you expand a group, it stays active regardless of the currently selected element. I have asked for this several times, but no luck yet.
