I have two Fitness installed. What is the Trial? @dan
Can you try logging out of Elements Cloud, restarting Elements, and then log back into your Cloud account, that should fix the issue for you.
Same problem here. Sign-out, restart and sign-in didn’t help with that. But not urgent, only a cosmetic issue.
I got logged out recently and logged in. Logged out now again, not solved but no big problem. I was just wondering what it is.
Do either of you have multiple copies of Elements installed on your Mac?
No, I don’t have a problem with elements. Deleting Fitness and reinstalling it doesn’t work either.
No, I have a single copy only installed in the /Applications folder - nothing else for sure. All other purchases look normal.
This is getting annoying. I suspect it has the same cause as the Fitness Trial. And yes, I’ve logged out and restarted. And no, I only have one version of Elements in my application folder. This behaviour reappeared with the update to 2.1.1. I’ll do a fresh install of Elements 2.1.1 tomorrow, which will probably fix it, but it is annoying.
