Interface suggestion
A small thing, but it is tiring on the eyes: can you makes these captions bolder? They are almost the same wight and emphasis as the subsidiary text.
Yes agreed! The inspector will be given a facelift at some point during the beta, so stay tuned for that!
I also notice you’re using an old V1 component, you should move all your components to the newer V2 versions. We have an old Dev Diary with info on that subject here:
