Intermittent problem - CMS Audio - sometimes works
Meta tag
Audio: trumpetpodcast16.m4a
Republished all - to make sure audio file got loaded again - (not overwriting CMS -doing all online)
Checked on line CMS - path is correct - name is correct
Sometimes will play - sometimes will not
Very Strange
Downloaded the CMS folder from the server and checked the meta data…
Is the problem the brackets? why are they there? [ ] see picture below
For some reason - I checked all the other podcast files - no brackets…
Must be that - How did it get added?
@ben seems to be adding brackets on the meta data in CMS V2
Screenshot 2026-06-05 at 4.03.27 PM
Screenshot 2026-06-05 at 4.03.37 PM
The field type in the online CMS is set to array, you need to switch it to resource for that folder/collection.
Thanx will change that - didn’t know about that…
quick update here to say we’ve fixed the underlying cause of those mystery square brackets :slightly_smiling_face:
The Online Editor’s frontmatter serialiser could turn a field into an array under certain conditions (emptying a field and refilling it was the usual trigger), and one corrupted file could then flip the detected field type for the whole folder — which is why a single podcast post had brackets when the rest didn’t.
From the next Elements 3 update, fields always save as plain strings, and re-saving an affected post in the editor cleans up any brackets already there. No more downloading the CMS folder to hunt for them :smiley:
