Issue with 2.0 beta
I was in a project this morning and everything that was white turned a dark grey and all the text that was white turned black. The first time it happened I was just going from one page of the project to the another page. The second time it happened I submitted a change to a button link. I’m using the system theme, not sure what’s causing it or if I just uncovered a bug. I attached screenshots. @dan let me know if you want to see the project and I DM you the link.
How it should look
Colors change for no reason
Double check settings for light mode / dark mode
I always turn dark mode off, but I did check to make sure it’s was still disabled.
Yes - my menu changes background color also - but not when previewed - usually close and reopen the site…
It tends to turn a darker shade of navy
@ajenks that’s strange, did a restart fix it? or is the project still like that?
If the project is still like that (or you have a way to recreate the issue), can you send the project over to forumsupport@realmacsoftware.com?
Restart fixes it up - no issues - just sometimes - randomly changes color…
Yes, restart fixes it and preview looks fine it’s just the WYSIWYG window. It’s happening to multiple projects. It does it randomly for no ryme or reason so it’s hard to duplicate it in a video.
I’m having exactly the same problem since the update…
It happens mainly in projects or “sections” that are older. It took a bit of work, but I fixed it by selecting the affected elements, right-clicking Background, and choosing “Reset group to default.”
I suspect there’s a conflict in older projects because of this fix:
Dark mode media queries are no longer generated when dark mode is disabled (hat-tip @Doobox)
@dan
I was able to capture the bug on video in the wild just now…
Btw, just switching back and forth between pages doesn’t trigger the bug. It only happens after clicking Preview in browser.
And here’s a longer video showing the bug and the fix.
I’m in dark mode in elements…
here’s what I’m seeing:
Dark Menu
Dark Audio Player
When I preview its fine…
When elements is in Light mode - no issues with colors or backgrounds….
