Hi Dan.
I have used the Snowstorm-scriptr, and now I can’t get rid of it.
I have tried removing the script, but it keeps coming back.
Is there anywhere else I need to delete it besides in the template?
Bjarne
If it’s appearing on your live site, you’ll need to make sure you re-publish your site.
You might also need to remove any “snow” components you have on your page(s).
Yes, that is the problem. I have now found the Page Setting - which was the problem.
So, thank you!
Perfect, glad it’s sorted!
