Just a little fun
it’s becoming a daily diary, nice work @upssjw
I try lots of proof of concept with just Elements some dont work as well as others, like tis one
check cube works in a page, different keyframes for inner and outer, flex works great instead of grid in certain circumstances
project without cube
elementsapp://downloadDocument/Bjbfyyz9fCdN
ok crazy each face can pull in cms, not finished yet
Did you do box in Elements or is it the same one I posted a few weeks ago as an HTML custom component? TIA
@PMUK
I posted this 3dcube about 12 months ago, there is an inner and outer box it has some math calcs in it
I wrote in Elements with the maths to change the size of the cube
Dan commented on it
https://forums.realmacsoftware.com/t/3d-cube-i-think-it-works-ok-now/44257?u=upssjw
Cool but is it “purely” in Elements now or is it an HTML Add on component. The reason I ask is I have a great HTML one but when I put it in a container it crashes. I was trying to do this for a product “dice” as I have 6 products and this looks cool on its own but as I try to put it in a container it crashes and I need to add background and put it in a header. TIA
I will release for free you can just have one cube and I am adding some change the animation controls yourself there are dropzones as well on each face
Can you post or send the code
elementsapp://downloadDocument/owv8ZFhJMNRr
Here is Project link, it used to just rotate but when I put it in a container its just “static” until hovered over
@PMUK
Added a hover no hover switch
elementsapp://downloadDocument/WIPgHrG6zITK
this is all I did didn’t check the rest of your code, other hovers in there
this was little more difficult posted before
shown this one before just never finished - prove I could do it, converting now into a 3d carousel, with /bg image etc /dropzones, horizontal and vertical
Steve I never doubt you at all your work is amazing! I recreated mine in HTML Components only but you seem to be able to weave your magic and do them in ELEMENTS only, which I find difficult. THANKS and keep up the brilliant work!
these are html components I wrote
Ah see now the other hovers send the squares across the faces too much sun light on my screen, no sun now, should have checked the code
I have a load which I have copied and adjusted and some are works in progress. Have a look here and see if theres any you like or can add your mastery to!
elementsapp://downloadDocument/pInCU8BS9TZi
This is my favourite!
Nice I prefer MovingPicture that is really cool, could be used to good effect with some controls. It is responsive
