when I have some time I might convert to Tailwind or as much as is possible and add controls
I am a medical person so I love the Medical ones, I am doing my blood clot website next and have added blood cells to the moving up one. But each to their own, I find Elements (Tailwinds) is so much better for creating and in my case copying and changing to suit my needs. I have NEVER been so into RW than I am now as I juste-loving and playing, and learning and keeping my brain active. Perhaps we should start and animation thread? ![]()
Although I have just done a ticker banner for the church that asked and then Dan slams me down with Iâm doing update to Elements tonight with a slider for twelve frames!![]()
Keep up the great work!
although these are just the same as the snippets I posted, just Tailwind basic animations hopeful these will be at least added to Elements
Theres, pings, bounces, pulse etc in one of the examples on my project i posted, you might be able to do something with these?
Hi Steve, thanks for these great examples. This reveal with upward sliding text, is just what I am looking forâŚUnfortunately, the link doesnât seem to work, Safari just reports it canât be opened. The video works, so it looks just like what I wantâŚ
try this, if you need help on setup let me know, just uses Elements components
I did this in Rapidweaver or very similar, check I could replicate in Elements, not finished for all break points.
The only thing missing is to be able to change entry direction for different screens sizes @ben and two directions ![]()
You should put yourself on Elements Marketplace offering to work for people who need a hand. Youâre doing some pretty cool stuff.
quick adjust elementsapp://downloadDocument/OLNbH5BDybcC
project https://share.cleanshot.com/WF96hm1DTrgTTL7X5Jh1
this version sits under the menu, not tested much
another take on reveal, thought, possible a svg in each corner reveal those directions
Oh thatâs nifty, I like!
That is definitely nifty.
However, I did find a minor anomaly that was easily fixed, where the pop-up could be displayed when hovering over the area to the left or top of the SVG. It was easy to fix by laying out the container that was triggering the pop-up in the desired position and then removing the spacing from that container so that the SVG fit into it.
Initially, I was confused by the title as I was expecting the use of a Reveal component.
Good stuff!
fixed in my version, try to confuse, âanother take on revealâ
Yes, that does it!
I also experimented with adding a lot of content to the pop-up and then isolated it, setting the overflow to scroll, which allowed me to display scrolling content within the pop-up. I can see a use case for this in one of my sites.
Thanks for showing us this idea.
Nice, you can do so much just with the basic components
I have one with a svg in each corner fit so much info in one area
been going through website css effects, and how many I can just do using Elements components, I have completed a few
