Keep a mobile menu when page is full width
Hello folks. I am using the North Eleven template. How do I make the menu like a hamburger even when running full size on Desktop please? I would like to keep the menu like three mobile lines instead of a full menu as there is too many items to be displayed on the top. Thank you for your help.
I don’t think the standard menu currently supports this. It is something you would have to build out yourself using some of the core components. There has been talk of adding this support, but it is not there yet.
as @handshaper says, you can just use Elements components
Hey Steve, can you me wich components and settings you used for this? :smiley:
@MikeV
here is the project, it only uses top menu and modal, not really tested it but turn into a global for use on each page, I can revert it to previous version if you need I spent 5 more mins with this version
elementsapp://downloadDocument/Glq9c3R4tn0g
you will need to delete the 2 extra grids and set the grids to 1
Thanks for your help folks. I have been building a site using the Northern Elements template. I have about twenty pages. They are running off the side of the menu and they can’t all fit in a row as the text will be tiny. I thought the simplest solution would be to keep the mobile hamburger menu that appears when the site is viewed on mobile. I don’t suppose there is a button you can press that will keep it as a mobile menu on all widths of the page?
@Lampfancy
could you not just use sub pages and put them all under one link
not with the current Elements menu component,
see link below for future updates
https://forums.realmacsoftware.com/t/no-navigation-visible-in-my-sticky-menu/49326/3?u=upssjw
Hello Steve - Thank you, that is a nice suggestion. I was wondering if I did that does it simply drop down when I click the main page that sub pages are all under? Thank you. - Lampfancy
@Lampfancy
Quick video, kinda of like this?
Place it on the right
Thank you Steve. I did this and it worked! You are amazing.
even this, the end can be positioned center left or right
