Lander Pro Theme
I am using the lander pro theme for my company website at renovisiondallas.com and wanted to know how to change the white “+” icon and “menu” to black so it can be seen easier.
Is this possible and if so, can you explain how to accomplish this?
Thanks to this great community
Doc
Hi John and thanks for using my themes.
This Classic theme shares the color with the titles (they have the same background).
edit in theme option panel: Layout Colors / Title and Slogan
if you need anything else let me know
BTW take a look now is available this layout also for Elements !!
in your project I can see a lot of submenu, the ELements version deliver more than one nav, so, you can use only the vertical version in your case, perhaps a vertical one is more suitable with 29 submenu :slight_smile: :open_mouth:
hope this helps
Great thank you - not sure how I missed that simple fix.
