Hi guys. Do you have any suggestions how to bring different flags into Elements menu? I am looking for a smart way to have different flag options inside the menu. Just tried something with SVG’s but that wasn’t really working well. As soon as I try to change the size a SVG inside the menu, all items get smaller as well. Thanks for your suggestions.
Try a modal
Hey Juergen @JGWeiland
Do you want to do something like below, but instead of the social icons with the country flags?
One way to do this as a top level menu would be to use the “Simple Menu” as you can assign page icons. Here’s a quick video showing how to do it:
Perhaps if you show what you’re trying to build, myself and @WeaverPixel will be able to guide you to an exact solution ![]()
Yes, exactly, that would be great. How do I do that? Thanks a lot
