Licence key from fastspring for cms2 does not work
I bought a licence key for cms2 from fastspring but it is not accepted. It should be in another format (xxxxx-xxxxx-xxxxx-xxxxx-xxxxx) and mine is only 5 times 4 digits. I don’t want to update to a beta version (that seems to be a solution).
If you have to update to the beta - it is very very solid.
I would imagine the next release would not be beta and would be 3.1 (my total guess)
Been on the betas since the first 3.0.X
Just the new version of tailwind is enough reason to use it….
Still no solution. The activation key is not accepted. Could have guessed that updating wouldn’t help. Anybody???
@dan please…
Check that your not copying an extra space before or after the code
It sometimes happens…
Yes, you’ll need to update to the beta of Elements 3 and re-publish your website, your CMS key will then work.
The beta is very stable, and we’re recommending all users upgrade as soon as possible to take advantage of al the fixes and improvements that have gone into Elements 3.
Let me know if you have any other questions.
