Unfortunately, I encounter the following problem. When I assign a link in a menu, it is initially stored. However, as soon as I change to the next menu entry to link it with a page, and then return to the previous one, the original entry is missing. After uploading the page, the links no longer work.
Hey Mike @Blumik
Never had something similar so far. Did you restart Elements?
If yes and still not working, you can sent me a download link as PN or mail and I can have a look
I think I’ve figured it out.
If you want to link in the menu of the Weaverpixel Template Studio, you can’t do that by clicking on the word twice and then selecting the page from the link below on the right. But I have to mark the word and then go to the link and select the page. Then it stays there too. Coincidence!
