List <ul> and <ol>
Since some people where looking. Thats a list component.
Allow custom color overwrite for single entries
This is looking great, simple and effective!
Yeah dropzone for cascading
Hi @dan,
thats the final result. Now for the ordered list.
The editor does not support previews for “before” pseudo elements. I am also using a custom css counter, since that is not supported in tailwind. Was the only way to get the 1.1, 1.2, 1.3 list style done.
While all this solves the problem of lists from a designer view of the world. The thing I keep seeing missing from Elements is what happens in the content creator use of the product. A designer (or myself) can design a site. Now I have to add, add, add content to it constantly. I want to be typing, maybe keystroking (ctrl, opt, command), not moving over to another panel and having to click + type + type + type + type.
Not sure what you mean. But wat you can do for now is have multi select and then edit all of them at the same time.
In elements there is an area which is called templates which is not yet done, but if you have your components set up and store them there you won’t need the whole setup anymore. Specially if you think about themes that could be purchased in the future.
Lists are a bit more complicated especially if you look at hierachical once.
For pure text type type type, that would be something for rapidweaver to answer.
