my list component does not jump, bit over the top with text size etc, indent as many times as you like, plus backgrounds, option , icons etc., not finished yet
it seems Markdown is also here. Will use it for bulleted paragraphs until Lists element will be improoved
We’re working on improving the list component now, hopefully a fix for text alignment will be in the next build. Stay tuned!
Great! It needs it as there are a lot of vertical alignment problems with the icon as well that I was not able to resolve.
For fine tuned list control I’d recommend building your own lists out of flex items.
Yes, I have realized this is going to have to be my solution as I can have a lot better control and it allows me to use a custom icon, if needed.
that why I have this plus sublists and sublists
