Lists hangs up
RapidWeaver Elements 2.0.0 beta 1 (24056): Lists works very slow when editing and hangs up. I’m alone with this experience?
Can you share the project via Elements Cloud so we can see if we can re-create the issue here?
will upload in a while
elementsapp://downloadDocument/WZUqYLUi0OaM
Sorry… I’ve had a quick look at your project, but I can’t seem to find any lists :grimacing: Can you let me know what page they are on how to re-create the “hang up” issue you’re seeing.
Thanks!
I added Lists but the performance when tried to edit was very slow. Could it be because of my Project size (around 130Mb)? My computer is C02GT3ZSQ7GN, works with Sonoma.
Size of project isn’t an issue, and I think you’re on a M1 iMac so that should also be fine.
Can you let me know what page your lists are on in the sample project? That way I can take a look and see if we can re-create the issue.
elementsapp://downloadDocument/PCauTxZKwso8
please find in “Apbedisana”
There is Tex element below the Liust element which I want to make as List. I just tried to copy text paragraphs one by one to List element. It was very annoying, the text fell into the next line after the bullet, I couldn’t get it to the right place with back delete. I also noticed it was slow. Then I deleted it and tried to drag the List element again. It didn’t work. It was as if I hadn’t dragged anything to the wrong place, it just didn’t appear
@dan this what happens when I copy text
@Wizard72 please below, are you pasting in a lot of text, or you cant re paste
looks same issue
@dan does this do the same on your list component
No, it stays below the bullet when I change screen size
Just did the same in new projet. Added List element. Added text element. Tried to copy text to list. It falls in the next line after bullet. If I try to fix it with backspace - does not work.
@Wizard72
it does not like all that text, copy less than a full line, text doesnt wrap properly it forces down to another line, if longer than width
looks like it works with less text only. When try to place more text there - problems start
just wrap and align to bullet, not doing that
as long as your text does not exceed the width, if you reduce the width of the screen and the texts wrap you will have the same issue
I’m seeing the same thing, when ever the text needs to start a new line it drops both lines below the list icon.
