I am facing an issue with local publishing, please see the attched video. I creeated a local publishing profile and selcted it from the publishing menu. When I select the publish option, it appears that website is being published. The window closes without any errors or warnings or any other messages. However, no files are created.
Sorry you’re having problems with local publishing! Here are a few tips to help get local export working smoothly
Double-check your local publishing path in Site Settings → Publishing. Make sure the folder exists and you have full write permissions.
Remove and re-add your local publishing destination to refresh the settings.
Make sure you’re using the latest version of RapidWeaver Elements, as updates often include export improvements.
If you’re still having trouble, would it be possible to upload your project to Elements Cloud so we can take a closer look. Just click the Cloud icon in the Elements toolbar while your project is open, sign in to your Elements Cloud account (or create one in-app if you need to), and follow the prompts to upload. You can manage your uploads in the Account Preferences window.
If you prefer to keep things private, feel free to send us a direct message with your project link once it’s uploaded. We’re happy to help either way!
