Login to server fail on project launch
Since v.1 was launched, I am presented with a server login dialog when I open my project file in Elements. This login always fails, and I have tried every possible password I have for my hosting company. After I give up and dismiss the login, when I go to my publishing setup and enter the ftp password, everything works just fine. Why is this happening?
Thanks,
Chris
Try the password for your Mac. I had the same problem.
Yes, your Mac password is required to unlock the keychain as that’s where your ftp password is securely stored.
Thanks!
Chris
and, if you are happy with it, select “Always Allow”
