Long Menus dropped vertical scrolling
Spaced to 4 - which is working now - thanx!
But you can only see 8 or so subpages - no scrolling
https://forums.realmacsoftware.com/t/mobil-menu-scrolling/48241/6?u=upssjw
Strange - TrumpetLessons.com started working now with scrolling…
It’s does not scroll on my iphone
It is now for some reason
Yes - strange how it does / doesn’t work
Sorry it the first site that doesn’t work didn’t realise there were two
http://trumpetstudio.com/
This one doesn’t scroll
Happening to other sites I’m editing also….
No scroll also did you mean the top bar look like this when dark mode is on
Dark mode - dark mode - dark mode
Usually turn it off…
Never tried to work with it - didn’t learn how…
I have dark mode on all the time, so thats why I see this
How does a site look for you when Dark mode is off? @upssjw
Silly question - what do people do with images on white backgrounds?
Just leave them?
Can’t see all on the list.
Needs to set bottom to 0
Yes - you can’t see and scrolling isn’t working…
Here’s what element bot says:
To enable dark mode in Elements, follow these steps:
  1. Theme Studio: Set your colors for light mode first. Use the Brand, Surface, and Text colors as your base.
  2. Toggle to Dark Mode: Use the Dark/Light Mode toggle button at the top of the editor to switch to dark mode. Adjust your colors for dark mode.
  3. Automatic Switching: Elements will automatically switch between light and dark mode based on the user’s system settings.
  4. Disable Dark Mode: If you prefer not to use dark mode, you can turn it off in the Project Settings. This will remove the UI option to toggle modes.
Scroll will work if you set bottom to 0
border-gray-100 shadow-lg + rounded-lg
Just a start
Your amazing!!! How did you figure that out…
Bottom was defaulted to: auto
Change to ‘0’
Scrolling started working…..
Trying other sites now…
