MAIRFOILS Hawai’i
:desktop_computer: MAIRFOILS Hawai’i
:hammer_and_wrench: Built with Elements by Robin Mair
:link: Visit the site: https://mairfoils.com/
:pencil: Builders Notes (optional):
I created this website for one of my businesses, which manufactures custom surfboard fins. It had been part of another one of my businesses but I decided to break it out and give it a website of its own. I still consider it a work in progress, but most of the work is done. Not your typical website as it is very focused on exposing what we have to offer.
Great site, what did you use for that cookie consent? Did you create your own custom component?
Thanks!
Yes, I did create my own custom component to handle this privacy consent. I have recently updated it so it now runs on the new CMS for all the data needed for the popups, including the privacy policy.
Once DevPacks become officially supported, I might distribute them for free to anyone interested.
Drop down. The sub pages just blinks for a second on my iPad Air 13”, they don’t stay down. I have the same problem with my test pages. But they work sometimes when I press long exactly on the little arrows. General seems to work, since it’s a folder, right?
Bug? @ben
Using Brave, I cannot get rid of the cookie consent banner no matter if I click accept or deny. I can open and close the privacy modal though.
Never used Brave, so I have no idea what is going on there. I would suspect there is something that is preventing the pop-up from accessing local storage.
Yes, GENERAL is a folder, while the other dropdowns are links that are nested in the page, as they are just anchor jumps within the page. This is going to change soon as I will be switching these menus to using a megamenu. But that will only be present on non-mobile systems.
I just tested this with Brave and I had no problems closing the consent pop-up. I just used a plain vanilla install of Brave, though.
Hm, I. might try again and disable all plugins.
