Something I was always able to do using Foundry was to use the equalize stack so that I could create areas of text that all hold equal heights. This comes incredibly handy with making cards all the same size. Is there a way to do this in Elements?
Yes, you need to set the container hight to full, that should do it. Let me know if you get stuck and I can put together a sample project!
So if I had a grid with multiple cards that would even out the heights of all cards to be the same? Thanks Dan!
This is really easy to do in Elements — just add a Grid and place Containers inside. The containers will stretch by default to all the same height inside a Grid. I quickly put together this example project, click to open it directly in Elements: elementsapp://downloadDocument/4wzPVsUAbgIK
Let us know if you have any more questions ![]()
Thank you so much for the quick reply. Much appreciated!
