Marquee Pro issue and Renewal
  • I wanted to renew my membership, but I think the system is set to auto-renew only on a specific date (for me, it’s the 19th of February). Please inform me if I can force the renewal now.
  • I have an issue with Marquee Pro: items are going off the page, but they do not loop. Please check the attached video.
  • Note: I am working on an Arabic project(RTL)
Hi @mmohdher that does indeed look like a bug, I’ll get this ticketed now and take a look ASAP. I’ll update you once I know what the issue is and how we can fix it :slight_smile:
Hi again @mmohdher
I’ve found the issue and just pushed an update to the Elements Store. If you update Marquee Pro from the store you should see the issue resolved next time you preview/publish :slight_smile:
We don’t support renewing subscriptions ahead of the renewal date. Your renewal happens automatically on the date of purchase (19th February), and there’s nothing you need to do on your end to make this happen.
Let me know if we can help with anything else :slight_smile:
One must open the credit card for online shopping or the transaction will not go trough. This happened to me, I opened it too late that day. Dan told me 17.00 UK time. @ben
Great. Thank you for your continuous support.
Dear Rapidweaver,
I am using the form component to build a workflow that enables users to register for paid services(without coding). I was unable to:
  • Enable or disable buttons or other components based on the value of a text or checkbox component (e.g., agreeing to the privacy policy is a condition for registration).
  • Create a subform that enables users to move back and forth and provide information based on categories(tabs may work if information flow is possible between tabs)
Please let me know whether these features will be available in a future release.
Thank you
Mustafa A. Mohdher
mmohdher@me.com
+966505542239
