Marquee Pro Questions
I’m having trouble with spacing in Marquee Pro. It seems to work fine on the desktop size but when I go down to the smartphone vertical size the bottom cuts off. I’m not sure what I’m doing wrong. I attached a photo of what I see when I preview. This is the link to my project.
elementsapp://downloadDocument/1ezCy82NFkk1
Also, in future updates will there be an option to adjust the fade sizes for different dimensions? I’d rather not have it on the smartphone vertical at since I want only one card at a time there, but as the size gets larger it looks nice.
Easy fix… It’s because you’re setting a specific height on the Marquee that is smaller than the content (I noticed this on each card too).
Here’s how to fix it :smiley:
Thanks Dan! I edited the sizing on the “cards” to auto as well and that fixed the problem. Looks fancy.
