Marquee pro visible items on moblie
Is it possible to set the amount of visible items on per screen size?
I would like one visible item on mobile, two on medium, three on large display.
You get the picture…
Hi @engrafiker
I’m pleased to share that we’ve just added this option to Marquee Pro. Visible Items is now fully responsive, so you can choose how many items appear on each device.
Just head over to the Elements Store to update Marquee Pro.
I like the new Marquee element. I found that even though it shows up correctly in the larger screens
this is what I get in the smaller devices.
any ideas how to eliminate the word wrap?
BTY - believe it or not, I am running this on 1.6.3.
I know I should be using 2.0
The only issue I had previewing is I had to publish to preview.
I had a failed attempt at upgrading to 2.0. I’ll try again soon.
