Marquee text spacing
I have a scrolling headline in marquee with some spaces in between the 2 headlines…all I do every week is alter the events…after the last update all the spaces have gone leaving on long line of text. I tried re inserting the spaces option space like ive always done but to no avail
Hi @Godber
I assume you are referring to the Marquee Pro component? If so, we haven’t updated that component recently, so if you’re seeing issues we’d need to see a live URL or get a copy of your project so we can help with this! :slight_smile:
elementsapp://downloadDocument/0nVw85LUMsPy
it was ok up until the 3.1 update
so it looks like you’re adding spaces between works in the text to create essentially two items in the Marquee component. Why not just add two items to the Marquee component?
Also, from seeing your project, and re-reading your post, I think you are having issues with spaces in the Text component, rather than the Marquee component?
I’m going to need more information from you to be able to help with this further. Can you tell me what you’re expecting this to look like, what it looked like before, and what you’re seeing now?
I had a line of text and to separate the two dates I used the option and space buttons to spread them out so I had a large gap inbetween the dates which was working ok up until the last update. so maybe is a text problem rather than a marque problem…either way the option/space combo doesnt work anymore for some reason
this what I see in the editor and using the option/space I can increase the gap between the dates but doesnt publish that anymore.
yes you could be right…added a text box with 2 words in and couldnt space them apart using option/space like we could before or just space
Hi @Godber
Thanks for the extra detail and the screenshot, that really helped. I’ve reproduced it here: extra spaces in a Text component show up in the editor but get squashed down to one when you publish. I have a fix in place for the next release!
Cheers
brilliant..thanks
