Marquee to Audio Player Anchor not working
A small sample project would showing the issue would be really helpful…
Sorry Dan - thought it was a repeatable common error - will upload after dinner…
Here it is:
elementsapp://downloadDocument/wpdqFE6fc8AG
work around - id the container - works to the container
I have not been able to get my anchors working properly. I have created an ID to the container and the anchor works as expected from link on same page, however if I link to the anchor from a separate page, the page does not scroll to the anchor :person_shrugging:t2:
Just tested it:
From marquee to alternate page scrolls to content
The ‘books’ link to alternate page….
Seems to work - doesn’t quite scroll perfectly….
Sometimes in order to get the anchors to scroll perfectly, you need to add some Tailwind classes in the Advanced settings.
This is what I use to get my anchors to scroll properly into view— scroll-mt-8
You can play with the value to tweak things, as needed.
Thank you!
