my Master Style Theme always switch back to the ‘Float’ Theme. At the moment I only use Foundation and it is the Theme that I set in Preferences, but after restart it switch to Float again. Any Idea?
I use the actual RW Version and MacOSX 10.11.2 but I got the same Problem with 10.10.5 and 10.9.5…
This works for me without issues here. I would suggest contacting Realmac support and see what they say.
Thanks Zeebe… good to know that it works at your Mac
I stopt sending Support Messages since I start working with RW6, because using the RW6 Support option freeze my Mac with Maverick. I didn’t test it with ElCaptain…
You can always use the old fashion way
support(at)realmacsoftware(dot)com
email still works
