Menu in Elements
Good morning,
On my test page Blumibyte I have the problem that I always have to press twice on the view (cell phone). Can someone tell me why this is or have I made a mistake?
Du meinst im Menü? Dann drück direkt auf den Text und nicht auf etwas außerhalb…
I only have to select the menu item on my phone and it jumps to the page no press twice
I also pressed once on my iPad - then menu with options to call or send SMS shows up. Normal behaviour.
If I target exactly, then that works. But unfortunately not always. Maybe the menu on a cell phone is also too small
